Identify Olds Engine
Old May 22, 2025 | 06:37 AM
LDPotts's Avatar
Does anyone know of a place to get information on Olds engine blocks. I have an Olds 455 engine that has been placed in 1978 GMC motorhome which is not what came out of the factory with, would have been Olds 403. I have been to GM Heritige Center. They sent me to Power Train Contsct Center where the only information they could provide is that the block number I have was produced some time between 1968 and 1971. Any suggestion of where else to go?
Old May 22, 2025 | 06:48 AM
67OAI's Avatar
Old(s)GuysRule
Let us know what specifically it is you wish to know/learn about your 455 engine please.
Old May 22, 2025 | 06:54 AM
LDPotts's Avatar
What I would like to find out is when GM built the engine was it placed in a vehicle or was it built to be used as a replacement engine/crate engine.
Old May 22, 2025 | 07:02 AM
The block casting number will tell you exactly what the engine is. The VIN derivative stamp will tell you the model year and will give you some idea of where it originally came from.
Casting number:
Old May 22, 2025 | 07:04 AM
Also, I deleted your duplicate post and gave your thread a more relevant title. You're more likely to get a response to your question if the thread title gives people an idea of the topic as opposed to your name.
Old May 24, 2025 | 08:27 AM
67OAI's Avatar
Old(s)GuysRule
Not mentioned above, if originally destined for installation in a vehicle it will have the VIN derivative stamped; if a replacement, marine, or irrigation engine it would have something other than a VIN derivative on that pad. All 455 CID blocks will have the casting number with the suffix "F".
3shields
Jun 17, 2024 06:19 AM
prlynch01
Nov 11, 2021 03:01 AM
pmertins
Feb 3, 2021 05:07 AM
Nastardly
Mar 25, 2015 06:22 AM
Mad Mex
Oct 6, 2014 11:52 AM
