1972 door lock question
Old November 6th, 2017, 02:11 PM
Hoffman2099's Avatar
Are the codes on the 1972 cutlass door locks supposed to be the same for the left and right or is the forth digit different to distinguish between left and right?
Hoffman2099 is offline
Old November 6th, 2017, 03:09 PM
Olds Fever
CRUZN 66's Avatar
If you are referring to the actual 4 digit key code, they should be the same for both doors... Each 4 digit code is a different six cut sequence for any given key... Sample chart below...
CRUZN 66 is offline
Old November 6th, 2017, 03:54 PM
Yeah, I was talking about the key codes. The forth digit is different on the locks so I guess the previous owner changed one of the locks at some point and it explains why my key only works on one lock.
Old November 6th, 2017, 10:18 PM
The RH and LH cylinders are identical. There would be no reason to make the codes different, and as shown above, the four character code specifies one key pattern. A different code specifies a different key pattern (and possibly even a different blank).
joe_padavano is offline
goldie442
August 21st, 2015 11:01 AM
jonn
December 2nd, 2014 12:06 PM
benjamin247
October 1st, 2014 07:23 PM
Maverick
April 22nd, 2014 05:04 AM
randomarrival
December 22nd, 2012 12:28 PM
Quick Reply: 1972 door lock question
