1970 cutlass s Ignition lock replacement
I already replaced the ignition cylinder but I can’t get it to lock in place. Basically if I pull on it it slides right back out. The shop mentioned taking the steering wheel apart to install a pin or a clip. I read the forums here and see no mention of that. Just wondering if that’s the case. I hope the column it’s self isn’t stripped. FYI I replaced the original lock and cylinder because it could start without the key and also be removed by simply pulling on it. Also it’s the standard column and not the tilt.
Thanks guys I knew something was off about that. I have the correct ignition cylinder it seems the column may be the issue because that tab does not lock to anything. I did read somewhere to push the cylinder in and turn clockwise with the key in to lock it in place. That's my last hope. Like I said when I got the car it had the correct gm cylinder in place but It was not locked in place either. We replaced it with a new gm cylinder but same issue occurs. At least it locks now. All this is part of the reason I have a GPS in the car.
Let's back up. Why are you replacing the lock cylinder in the first place? Was the steering column damaged? The spring tab simply snaps into a recess machined into the column housing. If the old one snapped into place, the new one will also. Who removed the old lock cylinder? Any chance the column housing was damaged during that process? Have you compared the old and new lock cylinders closely to verify the new one is not made wrong? This is another possible problem with repro parts.
The need to rotate the lock cylinder with the key while inserting depends on whether or not the rotating tab on the cylinder is aligned with the sector gear inside the housing. I've pulled these cylinders out and reinstalled them without the key, just taking care to not move anything in the meantime. Note that if the sector has been rotated with the cylinder out, you can use a flat blade screwdriver to align it prior to installing the cylinder.
Joe I think you are right the groove in the inside is rounded like the lip it connects to has been busted. I have a guy in my car club that has an old column for $40 bucks because he switched to a tilted column. That looks like my best option.
johnnyhawthorn
February 12th, 2014 11:47 AM
