1970 adjust auto cable
But if this is something that has recently started I would then that wouldn't solve the issue. My guess would be a stretched cable, or even a broken sleeve allowing slop in the movement.
The shifter mechanism itself wears and creates a bit of slop in the system. I had to play around with mine for quite a bit in order to get it fully into 1st at one end of travel and Park at the other end. Just keep making small adjustments on the shift arm slot and move it through the gears until it's adjusted right.
ARw30
Sep 22, 2013 08:23 PM
84oldsDelta88
Dec 11, 2009 06:19 AM
