1970 adjust auto cable
Old Aug 20, 2016 | 09:55 AM
Zr1bandit's Avatar
Any way to adjust the auto cable on the floor shift models?? have his hers shifter that seems to be out of adjusted. Thanks.
Old Aug 20, 2016 | 10:03 AM
svnt442's Avatar
What seems off? The cable is fixed at both ends and non adjustable.
Old Aug 20, 2016 | 10:08 AM
ELY442's Avatar
There's a slotted adjustment hole where the cable connects to the transmission shifter bracket.
Old Aug 20, 2016 | 10:37 AM
svnt442's Avatar
On the shift arm....right. I forgot about that one.
But if this is something that has recently started I would then that wouldn't solve the issue. My guess would be a stretched cable, or even a broken sleeve allowing slop in the movement.
Old Aug 20, 2016 | 11:02 AM
The shifter mechanism itself wears and creates a bit of slop in the system. I had to play around with mine for quite a bit in order to get it fully into 1st at one end of travel and Park at the other end. Just keep making small adjustments on the shift arm slot and move it through the gears until it's adjusted right.
Old Aug 20, 2016 | 12:00 PM
ELY442's Avatar
I had to use a small file to make the slot longer because it ran out of adjustment in order for the gears to go in. I had Park but no low gear or I had low gear but barely got in Park.
Old Aug 20, 2016 | 03:11 PM
Zr1bandit's Avatar
Shifter shows one gear when in fact it's in another. Will check the adjustment on the tranny you speak of.
ARw30
Sep 22, 2013 08:23 PM
bryndalfly
Jun 2, 2010 07:36 AM
84oldsDelta88
Dec 11, 2009 06:19 AM
wmachine
Jul 31, 2009 02:32 AM
74 Omega
Drivetrain/Differentials
May 26, 2008 10:43 AM
