1969 350 number six head question/advice
Old Sep 27, 2010 | 08:06 PM
michael hilsabeck's Avatar
two questions.
1. would anyone know what size of intake/exhaust valves come stock in these heads
2 what would you recommend as far as size makes a good compliment to edelbrock performer rpm hydraulic cam rpm range 1500-6500 .496 intake exhaust .520 with a duration at .006(290intake 300exhaust) and .0.50(224intake 234exhaust)degrees of course.
iam going to rebuild the heads anyways want to get it right. thanks much ahead of time
ps its a sunday driver/toy and i want it to move when i put my foot in it.
Old Sep 27, 2010 | 11:26 PM
Originally Posted by michael hilsabeck
two questions.
Old Sep 28, 2010 | 05:52 AM
2blu442's Avatar
Here's the link to the Wiki site which discusses heads:
http://www.oldsmobilewiki.com/index....ust_Port_Sizes
Your car should have #5 heads on it now, you can have the valve seats cut out and install the 2.00 intake valves. Doing some port work would also help your engine breath better. If you have time use the search option to find other threads on port work. John
Old Sep 28, 2010 | 07:55 AM
1969 heads
my numbers is cfu 403 869 i looked on the site i didnt see these numbers
Old Sep 28, 2010 | 08:44 AM
1969 heads 403 869 #6
can you tell me about these heads
Old Sep 28, 2010 | 09:27 AM
Better look again.
http://www.oldsmobilewiki.com/index....vative_Numbers
Originally Posted by Oldsmobilewiki
6 403859 64cc 1.880, 1.995 1.567, 1.624
All 1970 350s use the #6 head, 2bbl, 4bbl, or W-31, they all use it. The 2bbl and the 4bbl use exactly the same head. Same valves, springs, etc. Only the W-31 got the big valves and springs. Rotator style spring retainers were used on the intake and exhaust springs.
Also, I merged your other, identical question into this thread. Not sure what else you want to hear. The #6 head was used on all 350 motors during the 1970 model year. W-31s got the larger valves, but the casting is the same. Good choice for a 350 buildup, but not original on a 1969 model year engine.
Old Sep 28, 2010 | 10:35 AM
1969 oldsmoble cutlass convertible
So how wood you guys build this motor for power when you want it, all help would be appreciated. I'm not that good when it comes to intenal parts in the motor,thats why I need help that way I can get the right parts to build this motor.
Old Sep 28, 2010 | 11:11 AM
motor #
my motor#395558 big2 no my oil shaft #0226404
Old Sep 28, 2010 | 02:53 PM
tonycpe's Avatar
Joe, thanks thanks for posting this link.
I noticed in the small block head ID chart it says #5 heads not to use with replacement flat top pistons.
I was wondering why? hope i didn't read that foot note wrong.
Old Sep 28, 2010 | 04:07 PM
Good catch - I hadn't noticed that before. I'm confused by the footnote since obviously the #5 heads were used with flattop pistons in the 68-69 W-31 cars. One thing to keep in mind is that even the Wiki data originally came from the FAQ that originally came from excerpts from posts on the old Chubecto mail list server. These particular tables were originally generated by Chris Witt, probably in the early 1990s. Someone on ROP might want to ask him about it.
Old Sep 28, 2010 | 04:45 PM
Railguy's Avatar
I'd say the flat tops need the "eyebrows" cut in them for the valves.
Railguy
Old Sep 28, 2010 | 09:46 PM
thank you for the help
auto_editor
Wheels and Tires
Nov 23, 2010 12:58 PM
Oldsguy
Oct 27, 2010 07:06 AM
yeahbuddy
Jun 29, 2010 09:48 AM
cherokee coachworks
Apr 14, 2009 08:58 PM
J-(Chicago)
Sep 18, 2008 06:13 AM
