1969 350 number six head question/advice
two questions.
1. would anyone know what size of intake/exhaust valves come stock in these heads
2 what would you recommend as far as size makes a good compliment to edelbrock performer rpm hydraulic cam rpm range 1500-6500 .496 intake exhaust .520 with a duration at .006(290intake 300exhaust) and .0.50(224intake 234exhaust)degrees of course.
iam going to rebuild the heads anyways want to get it right. thanks much ahead of time
ps its a sunday driver/toy and i want it to move when i put my foot in it.
two questions.
Here's the link to the Wiki site which discusses heads:
http://www.oldsmobilewiki.com/index....ust_Port_Sizes
Your car should have #5 heads on it now, you can have the valve seats cut out and install the 2.00 intake valves. Doing some port work would also help your engine breath better. If you have time use the search option to find other threads on port work. John
http://www.oldsmobilewiki.com/index....vative_Numbers
Originally Posted by Oldsmobilewiki
6 403859 64cc 1.880, 1.995 1.567, 1.624
All 1970 350s use the #6 head, 2bbl, 4bbl, or W-31, they all use it. The 2bbl and the 4bbl use exactly the same head. Same valves, springs, etc. Only the W-31 got the big valves and springs. Rotator style spring retainers were used on the intake and exhaust springs.
1969 oldsmoble cutlass convertible
So how wood you guys build this motor for power when you want it, all help would be appreciated. I'm not that good when it comes to intenal parts in the motor,thats why I need help that way I can get the right parts to build this motor.
Joe, thanks thanks for posting this link.
I noticed in the small block head ID chart it says #5 heads not to use with replacement flat top pistons.
I was wondering why? hope i didn't read that foot note wrong.
cherokee coachworks
Apr 14, 2009 08:58 PM
