1957 Oldsmobile vin location
Old Jan 24, 2022 | 06:08 PM
tbear's Avatar
I have two 57 oldsmobiles and restoring one. One 57 has the vin tag above the lower door hinge. The other one is below the top hinge. Did the vin location vary from plant to plant? The one above the lower hinge is from Kansas City and the one below the top hinge is from Detroit. Thanks,
Old Jan 24, 2022 | 07:36 PM
Charlie Jones's Avatar
Phantom Phixer
The 1957 VIN tags were spot welded to the doorframe .
Are both tags attached by "dimple " spotwelds ?
If they are attached by rivits , screws , etc they have been removed and re-installed .
The VIN number was also stamped on the frame somewhere ( not sure where on this model ) .
The number on the doorpost tag and the one on the frame must match .
Old Jan 24, 2022 | 08:11 PM
tbear's Avatar
. One 88 has the vin, above lower hinge, is still there, sort of. Rust behind spot welds gave way but holes still there. The other car did not have a vin tag, however the vin tag (from other car) matches the spot weld holes below the top hinge. Just curious if different plants put vin tag in different place? Thanks,
Marty Webb
Jan 30, 2021 08:00 AM
CarGal
Sep 13, 2020 12:52 PM
jRoofgunner
Dec 14, 2012 07:08 AM
mike623
Apr 2, 2011 06:58 PM
johnbost
Jul 18, 2010 02:06 PM
