Power Distribution Block Location
Old Jan 4, 2015 | 02:01 AM
Pewter442's Avatar
Horn Relay Location
So the car didn't have power brakes originally but we have a power discuss brake conversion installed but with the new booster, master, and proportioning valve installed the stock location for the power distribution block is now covered by the proportioning valve. Have you guys ran into this problem? Do I just drill new holes to mount it? Oh it's a 67 442
Old Jan 4, 2015 | 05:30 AM
DLaz70OLDS98's Avatar
Are you talking about the horn relay?
Old Jan 4, 2015 | 06:19 AM
Pewter442's Avatar
You are absolutely correct. I forgot that was the horn relay.
Old Jan 4, 2015 | 07:18 AM
I am actually going to be installing my inner fender today so I will let you know if I have a similar problem. I would say that if the proportioning valve is in the way you will have to move the position of the horn relay. I'll keep you posted on how I make out with my install.
Old Jan 4, 2015 | 08:06 AM
Pewter442's Avatar
Ok thanks. I should be able to fire her up today if I go pick up a battery. I picked up 5 gallons of ethanol free gas on my way this morning to put in the tank. So she has fuel just needs fire now.
Old Jan 4, 2015 | 08:15 AM
Octania's Avatar
I thought it was located closer to the battery.
Old Jan 4, 2015 | 02:11 PM
Looks Like I have the same problem. After I got the inner fender installed I see the new proportion valve is right in the way. I can still use the hole closest to the front of the car and drill a new hole and use a washer or 2 to get the proper spacing. The only problem I see with moving the relay in this manner is it impacting the wire clip for the wire harness located on the fender. I also hate to just start drilling holes everywhere. I took some pictures of my set up.
Old Jan 4, 2015 | 03:57 PM
Pewter442's Avatar
Now what year is yours because it looks a bit different.
Old Jan 4, 2015 | 04:12 PM
My car is a 67 CS. I used the Inline tube lines for disc conversion that accommodate the use of headers.
Old Jan 4, 2015 | 04:38 PM
Pewter442's Avatar
Oh we used in line tube also but I'm not sure if he ordered they for headers.
garys 68
Brakes/Hydraulic Systems
Sep 18, 2012 10:20 AM
dgy
Apr 6, 2012 11:03 AM
Bluemeanie
Nov 5, 2011 09:25 AM
costpenn
Sep 13, 2011 03:40 PM
olds4life
May 4, 2011 09:57 AM
