No fire!
Old April 29th, 2014, 09:37 PM
nofirehelp's Avatar
Cool No fire!
Hey people wassup. I have a 1993, olds Achieva 3.3
I recently encountered a problem, I have no power when you turn the ignition on, replaced the batt with a brand new one, still nothing. Been trouble shooting the electrical side of things for days, still no answer, help.
nofirehelp is offline
Old April 29th, 2014, 10:26 PM
Welcome to the site, I moved your post here and deleted all the others that were scattered around.
Have you checked fuses and fusible links, alarm, cables, etc? Does the horn or dome lite, headlights or any thing work?
oldcutlass is offline
Old April 29th, 2014, 11:31 PM
nofirehelp's Avatar
Thanx I have checked all fuses, batt cables, etc. Gonna check the fusable link tomorrow, that is the only thing I didn't get a chance to get at.
nofirehelp's Avatar
No the horn doesn't blow.
Old April 29th, 2014, 11:32 PM
nofirehelp's Avatar
Everything is completely dead, no power at all when you turn the key.
Old April 29th, 2014, 11:34 PM
nofirehelp's Avatar
It's really weird, it has been working good all along.
Old April 30th, 2014, 04:01 AM
major noob
billmerbach's Avatar
Igntion switch?
billmerbach is offline
Old April 30th, 2014, 06:51 AM
Tedd Thompson's Avatar
Originally Posted by billmerbach
Igntion switch?
The horn is ahead of the ignition switch. If the horn does not blow my guess is it's probably the fusible link.Try and jump the battery hot lead to the horn relay and see if anything works. I would use a multimeter start at the battery and see where the juice stops. Have you checked all the ground straps? ...Just a few thoughts ...Tedd
Tedd Thompson is offline
Old April 30th, 2014, 07:13 AM
Do the headlights/ taillights/ brakelights work?
Old April 30th, 2014, 07:39 AM
major noob
Ahhhh ok
Old April 30th, 2014, 09:07 AM
Justin
oldstata's Avatar
If you have power , but no crank it could be the resistor style key the ingnition switch would need to be replaced. If this is the problem you can ohm out the old key and by pass it by soldering in the right ohm resistor
oldstata is offline
RustRocket
September 5th, 2014 10:14 PM
chris83
June 10th, 2009 10:33 AM
skubydobdo
October 25th, 2008 04:58 AM
skubydobdo
September 26th, 2008 11:43 PM
71rocket
August 24th, 2008 07:03 PM
Quick Reply: No fire!
