1967 cutlass Brake light indicator
Old Aug 24, 2025 | 08:14 AM
Paul Montoya's Avatar
Hello everyone I bought a 1967 cutlass with a 330 engine. I changed he front drums to disk brakes. The brakes light was always on before I did the change now it doesnt come on at all. Also my dash lights dont work. Before the conversion only one bulb worked in the dash. It was a dim light but it worked. I was just wondering if the brake light indicator has anything to do with the dash lights. Thank you
Old Aug 24, 2025 | 08:31 AM
The BRAKE idiot light gets power from the same INST fuse that powers all the other dash idiot lights. Changing the front brakes shouldn't have disturbed anything unless you were fiddling around under the dash and shorted something out or pulled out some wires inadvertently. This is where you crack open the Chassis Service Manual to the wiring diagram and trace that circuit until you find the problem. We're not going to be able to do that remotely.
Old Aug 26, 2025 | 07:41 PM
I do have the service manual. Im not experienced in wire chasing.Thank you for your knowledge
Old Aug 27, 2025 | 05:41 AM
Bee Saint Louis's Avatar
CutOvers Olds Parts Guys
Working on a 66 and did a drum to disc brake swap
On the new proportioning valve there’s a wire that goes to a brake switch if I’m not mistaken. Wondering if this your problem
Old Aug 27, 2025 | 10:23 AM
That would not cause an issue with the light not coming on, but one where it won't turn off.
Old Aug 30, 2025 | 12:02 AM
my brake light did stay on all the time when i did the brake conversion. then it just went out like the bulb burnt out
Old Aug 30, 2025 | 12:07 AM
I do remember a wire that wasnt hooked up. I didnt thiink it was a priority at the time. I also think the wire connector didnt match up to the valve, thats why I didnt do it
Old Aug 30, 2025 | 08:32 PM
I checked the INST fuse at the fuse box and it doent have any power. Do you know what that might mean?
Old Aug 30, 2025 | 09:47 PM
No power on both sides? Is the clip corroded, fuse blown?
Biggreek65
May 18, 2025 02:14 PM
Joey San Diego
Jul 15, 2024 12:33 PM
jereb00
Jun 13, 2018 07:09 AM
R_CK_R
Mar 19, 2015 01:13 PM
jo75olds
May 7, 2011 08:20 AM
