1988 Custom Cruiser Tailgate Light
Old Jun 13, 2018 | 05:18 AM
jereb00's Avatar
When is the tailgate light supposed to come one? When the brakes are hit? When the lights are on? Both?
Old Jun 13, 2018 | 05:56 AM
Your tail lights illuminate when your lights are turned on. Both brake lights and the center high mounted brake light should illuminate when the brakes are activated. Your turn signals should also flash when activated. What's wrong with your Custom Cruiser?
Old Jun 13, 2018 | 06:04 AM
jereb00's Avatar
The light on the tailgate doesn't come on - either with the lights on or when pushing the brakes. We aren't sure if it is a "running" light or a brake light. From our research, we think this is the third brake light. Are we correct?
Old Jun 13, 2018 | 06:55 AM
Yes. That is the Center High Mounted Stop Lamp. These were required on all cars by the govenrment starting in 1986. It should illuminate with your brake lights.
Here's a pic:
Old Jun 13, 2018 | 07:09 AM
CRUZN 66's Avatar
Olds Fever
If you have already tried changing the light bulb, then you may have a bad light socket or a wire issue... Something as simple as a ground wire to the tailgate or light itself could be the problem...
leroycjr
Aug 4, 2015 05:24 AM
tricordati
Jul 31, 2014 08:13 AM
5998DownUnder
Ninety-Eight
Apr 19, 2013 05:56 PM
Z-Fitch
May 26, 2012 03:48 PM
projectheaven
Jan 5, 2008 07:01 PM
