1969 N34 Steering wheel horn wire
Oct 10, 2022 | 05:42 PM
Crimson@69442
Jul 2021
Does this small black piece go in the hole where the wires inserts or does it go on the end of the wire inside the spring?
Thank You!
Crimson@69442
Find More Posts by Crimson@69442
Oct 10, 2022 | 07:45 PM
69442murph
Jul 2009
Ky
Mike,
This goes above the spring....
Hope this photo helps...
69442murph
Find More Posts by 69442murph
Oct 11, 2022 | 05:12 AM
Crimson@69442
Jul 2021
Thanks Tim!
Crimson@69442
Oct 11, 2022 | 06:04 AM
joe_padavano
Mar 2007
Northern VA
Once you push the spring and contact down into the hole in the cancel cam, that ring is a friction fit into the plastic tube to hold them in place.
joe_padavano
Find More Posts by joe_padavano
41 Olds horn wiring in steering column
Doctor's Olds
11:03 AM
68 Toronado Telescopic Steering Wheel - Connecting Horn Cam Wire?
68RocketAction
01:29 PM
powersteering
Gene Fettig
01:18 PM
Horn wire from steering column
jcmoretti
07:33 PM
Steering Wheel Swap - Horn Stopped Working
Maverick
04:20 PM
‘70 442 battery size
08:34 AM
