64 Cutlass Kick Down Switch
Old Jan 27, 2022 | 08:02 AM
rwf642's Avatar
This may be somewhere in a previous post but I can’t find it. Question is the switch mounted to carb on 64’s has 12v into switch at ignition on, 2 wires to trans solenoids both have 12v on. When wot one wire to trans turns 12v off the other remains on. Is switch malfunctioning? Trans does not kick down when WOT. Should switch be on or off for both wires? Or just one. Maybe solenoids not working but switch is first to diagnose.
Old Jan 27, 2022 | 11:16 AM
Rallye469's Avatar
ISn't there a fuse in the fuse box as well?
-peter
Old Jan 27, 2022 | 10:01 PM
The black wire operates the switch pitch solenoid and should have power at both idle and WOT. The white wire operated the kickdown and should only have power at WOT.
Old Jan 28, 2022 | 04:15 AM
Rallye469's Avatar
Joe, what happens if the pitch stator doesn’t have power?
Like if the fuse blows?
-peter
Old Jan 28, 2022 | 05:54 AM
-peter
It just stays at the low stall speed position.
MBOlds98
Feb 10, 2021 06:37 PM
RM1964
Jun 2, 2019 04:41 PM
steverw
Aug 21, 2017 08:41 AM
CroixDad
Mar 25, 2013 11:14 AM
Jetstar88
May 21, 2007 12:33 PM
