88 1998 tail lights and cluster light off chimes on opening door
Old Aug 13, 2020 | 09:06 AM
PerryJeff's Avatar
Hi I have figured out it is a fuse but cant find the correct one. My car has left and right inside fuse box and underhood fuse box. I can not find good break out on the fuse numbers. I found one place that it is fuse #37 but can't
find a list of numbers for the box I have checked all of the upper fuses in LH and RH below and they all look good.
Old Aug 13, 2020 | 04:52 PM
Your best bet is a factory service manual. It would also help if you tell us what year your working on.
Old Aug 13, 2020 | 05:06 PM
PerryJeff's Avatar
Thanks for the reply Matt its a 1998 Olds 88. I looked in the Service Manual and it had details on the left and right side fuse boxs inside the the car but nothing at all about the under the hood fuse box.
I was able to find the scematic I posted on the internet but with no details on it. They have 20 40 and 60 amp fuses above the relays in the under the hood. They even have spare fuses right there which is great.I found one that was 60 amp labeled Misc lights and figured that was it but the fuses were still good.
I did have some lose wires at the bumper that were hanging down some which I taped the frayed wires up but I am guessing that was were my short happened that blew the fuse. The brake lights still work but no other tail lights.
Thanks for any help on this.
Jeff
Old Aug 14, 2020 | 04:03 AM
Wow, I feel stupid. You stated the year in the title and missed it.
The electrical information is in section 8 of the service manual. There is a subsection labeled chimes and warnings, it should have all the info you need to diagnose the issue. There are inputs to the chime module for the door jamb switch, taillight feed, seat belt, etc. Your going to have to determine if each input does what it’s suppose to do. If everything works as designed, most likely you have a bad chime module
Old Aug 14, 2020 | 04:09 AM
PerryJeff's Avatar
Thanks Matt I will look there and check that out. That is going in a direction I had not thought of at all.
Hopefully that solves my issue.
56dunemobile
Apr 1, 2020 04:31 PM
Kensey
Jul 5, 2018 07:58 AM
garyfoust
Nov 23, 2017 04:37 AM
Southern_Hospitality
Aug 19, 2011 05:46 PM
Big John 85
Jun 14, 2009 05:37 PM
