Wiring issue
Old Dec 28, 2019 | 12:02 PM
56dunemobile's Avatar
Wiring issue
My tail & interior lights won’t work on my 1956 Olds S88 convertible. Any ideas where to start?
Old Dec 28, 2019 | 12:41 PM
Tedd Thompson's Avatar
Fuse holder under drivers side dash fifth fuse down, probably marked tail light, should be a 7.5 amp fuse if it is a fuse. Could be just dirty fuse holder Other wise see where the juice stops or most likely where is the bad ground? Keep us informed on what you find....Tedd
Old Dec 28, 2019 | 01:30 PM
Thanks Tedd, I’ve installed new fuses, but will scuff the holder to make sure. Suspect it is a ground issue since the interior lights and gas gauge work intermittently.
Old Dec 30, 2019 | 07:33 AM
Gas gauge could be a separate issue. Oldsmobile of this era used a Micky Mouse ground system on the gas tank to ground it. There is a clamp on the gas line near the tank that most likely has corroded and will give you fits finding. Most bypass this ground and and go straight to the frame with a tapped hole and a small bolt.
If you can't find where the juice to the tail lights stops check the bolts that attach the tail light lens to the rear end of the car, though tight they sometimes don't make a good complete ground and you will have a no light or intermittent light issue.
If you could list what doesn't work and what does (all the lights and accessories) it would be a help isolating /figuring out what the issue or issues are..... Tedd
Old Dec 30, 2019 | 09:55 AM
ignachuck's Avatar
Frank Ignachuck
Here's the schematic, in case you don't have one:
I think I remember having your problem with my '56 once. Since nothing worked on my car when I bought it, I'll look through my notes and get back to you. Most problems were fixed by cleaning connections and wiggling wires, as Tedd suggested above.
Old Mar 16, 2020 | 01:53 PM
Wiring issue SOLVED
Ted & all,
Located the issue(s). Truck light Assyrian was grounded along with both front parking lamps. I had to replace the turn signal switch, brake switch and the headlight switch as well. Good news I have lights, turn signals and brake lights. Thanks for all the help.
Old Apr 1, 2020 | 04:31 PM
Almost road ready
Cautiousmoving
Oct 24, 2019 09:21 PM
2blu442
Mar 17, 2017 06:37 PM
LAolds
Aug 19, 2013 11:33 AM
mauls
Jun 8, 2010 03:43 PM
Yanqui84@gmail.com
Feb 1, 2010 04:53 PM
