1972 Olds 455 starter question
Old Dec 28, 2019 | 01:40 PM
garys 68&72's Avatar
I'm building a wire harness in a 72 Olds jet boat. Open engine compartment, so it looks like an auto starter. The starter has no markings on the solenoid posts. I'm guessing the outside post is the crank/start post, the inner one is the ballast resistor bypass. Can anyone confirm?
Old Dec 28, 2019 | 02:27 PM
Old Dec 28, 2019 | 07:23 PM
The “S” terminal is the start wire. The other one is “R” , it supplies battery voltage to the coil, bypassing the resistance wire or ballast resistor. If your using electronic ignition, the S terminal is all you need for the starter to crank.
Old Dec 28, 2019 | 11:24 PM
Thanks, that's what mine looks like, just no markings. Probably Chinese aftermarket.
Old Dec 29, 2019 | 05:53 AM
stellar's Avatar
stellar
I'm not sure an open engine compartment would make it exempt from having a marine rated starter or not. You may want to check with Coast Guard regulations. If it is supposed to have a marine starter any insurance claim would be denied. If it were mine, I would want the Marine starter just for the extra safety. I sure would hate to ruin a good day fishing at the middle of the lake, then go to start it and have a fire. It wouldn't be any fun swimming back to shore watching my boat burn. It might be a good idea to check the regulations. I know the Marine starter is a bit more expensive, but it might be worth it.
Kyle's77cutlass
Jun 16, 2019 09:19 PM
Dan K
Jul 24, 2017 09:20 AM
RALLYE KID
Oct 7, 2015 06:07 PM
gtaa9
Jul 16, 2015 11:24 AM
timothypaul
Aug 2, 2013 07:40 AM
