Quick question - loose starter wire '70 455 Cutlass
Old Jul 22, 2017 | 11:40 AM
Dan K's Avatar
1970 Cutlass 455 auto - stock engine / full size starter
Quick question - a friend wants to borrow the olds for a parade today. Have had intermittent starting problems, but think it's a loose connection at the start because if I jiggle the heavy gauge red power cable going to starter it will eventually get a connection at start.
So, don't see an angle to get at the post this wire connects to at the starter end - so question is do I need to drop the starter to get at it? Just trying to be as lazy as possible. Thx
Old Jul 22, 2017 | 12:18 PM
ecwieder's Avatar
Eric
If all the parts are installed, ie. the motor mount heat shield, it's near impossible to get at the nut on the starter solenoid without dropping the starter. Even if the motor mount heat shield is missing it takes the patience of Job to pull it off.
Old Jul 22, 2017 | 12:30 PM
Dan K's Avatar
Thank you, yes heat shield etc. in place. Deep sigh, I guess I will actually have to do some work.. I don't have the patience of Job, just Dan. Which is pretty short!
Old Jul 22, 2017 | 02:49 PM
I suspect that the problem is a bad solenoid, not a loose wire. If the wire were loose, you'd see and hear arcing when you tried to start it.
The solenoid has a copper contact disk that connects the battery terminal to the starter winding terminal inside the end cap of the solenoid. The fact that these terminals are hot when the disk contacts them causes arcing. That's just a fact of life. Eventually the arcing damages the disk, causing excessive resistance and no-start. The disk does rotate slightly every time you try to start the motor, so if the bad spot lines up with the contacts and causes a no-start, several attempts to start will eventually rotate the disk to a good spot. Unless you know the solenoid is good, I'd replace it anyway when the starter comes down.
Old Jul 22, 2017 | 03:09 PM
My2nd 69 442's Avatar
Please be sure to disconnect the ground wire at the battery before ANY work on the starter
Old Jul 24, 2017 | 08:47 AM
Dan K's Avatar
Thanks.
Joe, I suspect you are correct, after engine cooled down was able to at least get a finger on the connection at the starter end so does not seem loose. Engine was just rebuilt year before last and cable is new at that time so don't think it's a corrosion issue either but you never know with connections. But will order a replacement as a "MAW".
Planning on ordering this from Rock Auto as a replacement unless anyone happens to have a better suggestion:
http://www.rockauto.com/en/moreinfo....213489&jsn=407
Old Jul 24, 2017 | 09:20 AM
You don't need the whole starter, just the solenoid. You can get it local or from Rockauto.
http://www.rockauto.com/en/catalog/o...+solenoid,4188
roberer
Sep 22, 2015 09:36 AM
coppercutlass
Dec 28, 2011 04:48 PM
68cutlassdriver
Mar 6, 2011 11:53 AM
semper-fi
Dec 22, 2009 12:45 PM
abroadbent
Jul 27, 2008 06:58 PM
