67 442 horn only clicks after replacing battery
Old November 5th, 2018, 04:56 PM
matchek's Avatar
Hi I just replaced my battery on my 442 and now the horn just clicks, but not horn sound. Probably just the horn relay. Any ideas on what happened?
matchek is offline
Old November 5th, 2018, 05:07 PM
Did you disturb the wiring in front of the battery near the radiator support?
oldcutlass is online now
Old November 5th, 2018, 05:20 PM
matchek's Avatar
I may have it was a tight fit. I cannot see in front of the battery as it slips under it. I take it I should remove the battery and shine a flashlight there? Not sure where you are referring. Thank you for replying.
matchek is offline
Old November 5th, 2018, 05:33 PM
72455's Avatar
If you hear a click that's the relay...I would double-check the wiring going to the horns.
72455 is online now
Old November 5th, 2018, 06:06 PM
matchek's Avatar
I see what happened. Some of the jostling knocked off a lost connection at the horn itself. It barely is holding on there. Wow with the new battery, the horn is pretty loud! Is that normal or should I tone it down.
By the way, they sold me these circular pads to go on the terminals. Do they work much? Thanks guys.
matchek is offline
Old November 5th, 2018, 06:11 PM
Normal, leave it alone you probably had a bad connection for a while and the battery install did it in.
Old November 5th, 2018, 06:16 PM
72455's Avatar
The pads do work...I have them on my daily driver and have yet to deal with corrosion or acid buildup...and I put the battery in over 2 years ago.
72455 is online now
Old November 5th, 2018, 06:30 PM
I'm not big on the pads. As the battery gases out, which is normal, the pads act like little sponges collecting moisture and acid which leads to corrosion. At least that's my experience with them.
Old November 6th, 2018, 08:29 AM
Here's some info on preventing corrosion on battery terminals.
https://itstillruns.com/inexpensive-...n-5770493.html
Fun71 is offline
tbristol
June 16th, 2014 09:02 AM
CrazedCountryRebel
December 14th, 2012 08:20 AM
brown7373
July 6th, 2012 12:55 PM
Jamesbo
February 6th, 2011 12:08 PM
troberts6
July 18th, 2007 05:34 PM
Quick Reply: 67 442 horn only clicks after replacing battery
