From no gauges to having gauges
1st photo is the speedometer connector. The gauge package connector comes off this. I've removed the terminal with a small flat pick tool
2nd photo is the gauge connector pigtails inserted into the speedometer connector, not connected to the harness yet.
3rd photo wiring finished. The gauge setup I put in was from a '82-85 B/C car, so I had to cut a hole in the dash panel for the window switch.
An 85 will probably have the pigtail on the harness. I swapped those gauges into an '83 Delta 88 I had years ago and it had the connector. If not, it's not too hard to add the connector. I added it to my '77 Delta 88.
