1157 LED Tailight Bulbs
Old September 20th, 2018, 02:54 PM
pettrix's Avatar
Any recommendations for a 1972 with 1157 taillight bulbs? I want to convert to a LED 1157 taillight bulb that will work with the turn signal setup. Prefer NOT to use a resistor as that has been show to draw as much power as a halogen.
pettrix is offline
Old September 20th, 2018, 04:33 PM
Gary
VC455's Avatar
I've been looking for bulbs as well. Here are some things I've learned...
  1. The 1157 LED bulbs I've found don't have as much difference in brightness between taillight and stop light as the factory bulbs do. Stop is bright enough but taillight is much too bright. When I put on the brakes at night I want someone behind to notice something has changed!
  2. You need to buy a red LED for behind the red lens. The light from a white LED will be much dimmer by the time only some of the wavelengths make it through the red lens. Lumen ratings of the red bulbs look low, but they will look good (except for point one).
  3. You won't need a resistor with any LED bulb to avoid ricer flash. There's no computer flashing the lights on our classics. Just replace your flasher with an electronic version.
Tell us if you find a good bulb.
VC455 is offline
Old September 20th, 2018, 05:34 PM
therobski's Avatar
I learned my lesson, don't buy the junk 6-10 piece packs on the cheap. This is what I have on the 64 F-85: http://www.bulbconnection.com/ViewSI...iABEgJGgvD_BwE
x2 need to replace the flasher with an electronic version....
therobski is offline
Old September 20th, 2018, 07:27 PM
pettrix's Avatar
How do you like the Sylvania LEDs? Is there a noticeable difference from running light to brake light?
What flasher did you use to make it compatible with the LEDs?
pettrix is offline
Old September 21st, 2018, 08:43 AM
I used these projector-style LEDs in the back of my 67 Delta. I did not change the flasher. I'm very happy with them. The side LEDs light up the reflector in the tail light buckets, and the projector has a wide angle lens to help spread the light across the lens.
joe_padavano is offline
Old September 21st, 2018, 07:26 PM
jaunty75's Avatar
Do you have a part number or source for those? I might like to try those in my '67 Delta.
Thanks.
jaunty75 is offline
Old September 21st, 2018, 08:08 PM
Mr Nick's Avatar
https://secure.cougarpartscatalog.com/plasma2.html
These are pricey, but well worth it. They light up instantly, and are brighter when on 'low' and much brighter on 'high.' They illuminate the whole lens very evenly, no bright or dark spots.
Mr Nick is offline
Old September 21st, 2018, 08:14 PM
jaunty75's Avatar
Thanks. That link is for red bulbs. Is that what I should do? The factory bulbs are white. It seems kind of like overkill to put a red light behind a red lens.
jaunty75 is offline
Old September 22nd, 2018, 12:59 AM
pettrix's Avatar
LED's put out a much brighter spectrum so a white LED would wash out the red lens and appear more white than red. Hence the reason why red LED bulbs are the way to go. You don't want to have white brake lights.
pettrix is offline
Old September 22nd, 2018, 06:04 AM
Thanks.
I got them from one of the LED bulb vendors at Carlisle. He's always there, so I'll snag a business card next week and post the info.
Old September 22nd, 2018, 07:12 AM
Gary
VC455's Avatar
...brighter when on 'low' and much brighter on 'high.'
From the referenced web site:
  • Brightness: 90 lumens (low), 200 lumens (high)
From their figures, the stop light is about twice as bright as the running light. Stock 1157s have from 11 to 16 times the brightness for stop light versus running light.
This is a great example of point 1 in post 2.
Perhaps if some of the LEDs are devoted 100% to the running light, you could poke out some of those eyes and get a better ratio of stop to running brightness.
If that big mismatch of brightness could be solved, the bulb has a lot of fine features.
VC455 is offline
Old September 22nd, 2018, 07:33 AM
jaunty75's Avatar
Amazon has them, but for a bit higher price than that Cougar parts place linked to above.
https://www.amazon.com/1157-Single-Filament-PLASMA-Brilliant/dp/B01ACKV72W/ref=sr_1_3?ie=UTF8&qid=1537626664&sr=8-3&keywords=plasma+led+1157&dpID=312Kpd3YkKL&preST=_SX300_QL70_&dpSrc=srch https://www.amazon.com/1157-Single-Filament-PLASMA-Brilliant/dp/B01ACKV72W/ref=sr_1_3?ie=UTF8&qid=1537626664&sr=8-3&keywords=plasma+led+1157&dpID=312Kpd3YkKL&preST=_SX300_QL70_&dpSrc=srch
jaunty75 is offline
Old September 22nd, 2018, 10:53 AM
therobski's Avatar
This is the flasher I am using. Yes there is big difference between the brake light and the tail light brightness. I used their amber light for the front also. All works well together.
Old September 28th, 2018, 07:09 PM
pettrix's Avatar
What was the flasher #??
I got one that looked similar on Amazon and it is not working properly.
EF32RLNP
Amazon Amazon
pettrix is offline
Old September 28th, 2018, 09:15 PM
RandyS's Avatar
That is the correct flasher. Did you ground the ground wire?
RandyS is offline
Old September 29th, 2018, 12:53 AM
pettrix's Avatar
I think I figured it out. If I remove the 1157 front amber bumper LED's, then the flasher and everything works. Somehow the front amber LEDs are causing an issue. Not sure but after installing the incandescent bulbs, all is fine.
pettrix is offline
Old September 29th, 2018, 01:00 AM
pettrix's Avatar
Where does one get a new 1157 socket for the rear taillights? The OEM socket is rusted and not functioning like it should?
pettrix is offline
Old September 29th, 2018, 10:16 PM
pettrix's Avatar
I found these on Amazon. Will this fit into a 72 Olds Cutlass rear tail light socket?
https://www.amazon.com/uxcell-Plastic-Water-Resist-Socket/dp/B00EDJWR8W/ref=sr_1_14?ie=UTF8&qid=1538283831&sr=8-14&keywords=1157+bulb+socket https://www.amazon.com/uxcell-Plastic-Water-Resist-Socket/dp/B00EDJWR8W/ref=sr_1_14?ie=UTF8&qid=1538283831&sr=8-14&keywords=1157+bulb+socket
pettrix is offline
Old September 30th, 2018, 06:04 AM
The original sockets are swaged into the tail light housings. Replacement requires a lot of work. Those twist-in sockets do not fit in the stock housings.
Old September 30th, 2018, 07:06 AM
Mr Nick's Avatar
Depending how badly rusted it is, I've been able to free up sockets with sticking pins using WD40 and a metal pick, with the tail light harness unplugged of course.
Mr Nick is offline
Old September 30th, 2018, 05:37 PM
pettrix's Avatar
I also noticed that the upper drivers side tail light works as a driving light but then the brake light and turn signal portion will not work. The lower lights up fine, it's just the upper.
What would cause that? A bad socket or something in the wiring?
pettrix is offline
Old October 6th, 2018, 02:28 AM
pettrix's Avatar
Here are my LED updates. Running lights vs brake lights. The LEDs are at least 2x brighter than the incandescent bulbs. They don't run hot like the incandescent and pull about 1/4 of the voltage/amperage.
The glare is from the camera, not present in real life.
Running Lights
Brake Lights
pettrix is offline
Old October 7th, 2018, 07:02 AM
To follow up on this, I spoke to the vendor at Carlisle this week. He does not do mail order. He only sells at shows. Sorry.
Old October 7th, 2018, 11:31 AM
therobski's Avatar
Once upon a time a had to deal with rear taillight sockets rusted etc. What I did to fix one of them is I put a tiny drop of solder on each contact on the bulb and that helped a bunch if the contact springs are not good. If the socket is worth saving put some Evapo-rust in a can and soak the socket see what happens.
Old January 12th, 2020, 12:04 PM
Reese Jacobs's Avatar
Not to dig up an old thread, but I'm converting my taillights/signals to LED's now and I'm wanting to know the best bulbs for the scenario. For starters, I've got an electronic flasher in my amazon cart and I just want a LED bulb/brand that will avoid point one in the 2nd post ^. Being 2020 now, I'm thinking that projector style LED's will provide the best 360 degree coverage to fill out the lens. I see that there was a recommendation for the "plasma" bulb but does anyone have any other tried and tested brand/type (just for options) that I don't have to roll the dice on. Thanks guys.
Reese Jacobs is offline
Old January 12th, 2020, 05:24 PM
Gary
VC455's Avatar
Originally Posted by Reese Jacobs
I just want a LED bulb/brand that will avoid point one in the 2nd post.
I eventually fixed the overly-bright taillights by experimenting with resistors that I eventually incorporated in the rear harness wiring.
VC455 is offline
442fanatic
August 15th, 2021 02:24 PM
mitchy
February 8th, 2016 09:34 AM
ATrain1
January 31st, 2013 03:50 AM
WoofWagon
October 13th, 2011 07:45 PM
jeffreyalman
May 3rd, 2010 12:38 PM
Quick Reply: 1157 LED Tailight Bulbs
