trunk grommet- ‘67 cutlass
Old August 1st, 2018, 04:15 AM
Al
My Grandma's 67 Cutlass's Avatar
Hi, I am not sure if this is the right area to post this but I am looking for the correct rubber grommet that goes around the tail light wires as they enter the trunk. My vehicle is a 67 cutlass. Any help would be appreciated. Thank you
My Grandma's 67 Cutlass is offline
Old August 1st, 2018, 04:31 AM
35tac's Avatar
I had a similar problem with my 66 because the backup light harness coming into the trunk needed to be installed. If you have a 67 assembly manual what does it show? My 66 manual showed it. Best thing to do is determine the hole diameter somehow. Once done get in touch with Steele Rubber products, they should have what you need.
Wayne
35tac is offline
Old August 1st, 2018, 05:56 AM
Al
I don’t have a manual, but thank you for the info. I will look into it
Old August 1st, 2018, 06:02 AM
35tac's Avatar
Forgot to mention one more source. Check in with someone who is parting out a similar car and same model. Was a good source for me as they provided a beat up sample that will help finding a substitute.
Wayne
35tac is offline
Old August 1st, 2018, 06:13 AM
Al
Good idea, thanks again
pfriesen
Ninety-Eight
May 29th, 2021 07:50 PM
DoubleU30
September 28th, 2018 06:30 PM
September 16th, 2010 09:35 AM
squirell
Tech Editor's Desk
June 30th, 2009 08:29 AM
Quick Reply: trunk grommet- ‘67 cutlass
