Horn honk when turning right???
Old Jul 29, 2018 | 08:44 PM
72455's Avatar
1972 U code Supreme
So here's one for you electrical experts to ponder over...
I just replaced the horn relay and the turn signal switch/harness in my '72 Cutlass Supreme. Upon completion, everything worked as it should. Now,(for reasons that are beyond me) , when I turn the steering wheel to the right, the horn will beep from about the 4 o'clock position to about the 5' ocloo'k
position. I've checked for grounding on the horn wire but notta. Any ideas?
Thanks,
Dave😁
Old Jul 29, 2018 | 09:24 PM
Remove the steering wheel, its in the horn contact or the black horn wire is chaffed to ground. Or you can just make left hand turns...
Old Aug 1, 2018 | 07:27 PM
72455's Avatar
1972 U code Supreme
Got my horn working right...it was an issue with the contact ring. Thanks for all the help and suggestions.
Old Aug 2, 2018 | 05:04 AM
Glad you followed up with the fix.
Hdmike444
Jun 3, 2019 08:08 PM
70Post
Jul 23, 2018 08:03 PM
matchek
Aug 20, 2017 11:34 AM
sealw98
Jun 16, 2016 06:32 PM
tschie
Tech Editor's Desk
Nov 11, 2015 04:35 AM
