trunk grommet- 67 cutlass
Hi, I am not sure if this is the right area to post this but I am looking for the correct rubber grommet that goes around the tail light wires as they enter the trunk. My vehicle is a 67 cutlass. Any help would be appreciated. Thank you
I had a similar problem with my 66 because the backup light harness coming into the trunk needed to be installed. If you have a 67 assembly manual what does it show? My 66 manual showed it. Best thing to do is determine the hole diameter somehow. Once done get in touch with Steele Rubber products, they should have what you need.
Wayne
Wayne
Forgot to mention one more source. Check in with someone who is parting out a similar car and same model. Was a good source for me as they provided a beat up sample that will help finding a substitute.
Wayne
Wayne
squirell
Tech Editor's Desk
June 30th, 2009 08:29 AM
