Neutral Safety Wires
Old Sep 4, 2017 | 06:00 PM
onofre442's Avatar
im installing the hurst quarter stick this week and would like to use the original neutral safety wires....I've got two purple wires (12gauge), one is solid and one with a white stripe on each end, not striped all the way. Which wire is connected to the starter?
Old Sep 4, 2017 | 06:18 PM
The solid purple.
Old Sep 4, 2017 | 08:27 PM
onofre442's Avatar
Thank you!!
Old Sep 5, 2017 | 06:02 AM
The purple with YELLOW stripe is from the ignition switch, the solid purple is from the neutral safety switch to the starter solenoid
Old Sep 5, 2017 | 07:38 AM
Of course, you could also simply probe each terminal in the connector with a test light while holding the key in the START position. The one from the key will have power and the other one won't.
Old Sep 5, 2017 | 07:48 AM
With all that said you still need both wires and they connect through a simple switch that does not care which wire is connected to either side as long as they are on the correct switch for your new shifter.
Old Sep 5, 2017 | 08:33 AM
onofre442's Avatar
thank you, lots of help here!!!!
Flye
Mar 30, 2009 03:45 PM
70 ctls
Jan 28, 2009 03:20 PM
OhMyOlds
Aurora
Oct 21, 2007 12:44 AM
footbrake
Jun 12, 2006 06:10 PM
oldsnut7098
Aug 10, 2003 10:06 PM
