1972 cutlass no lights and most of interior does not work
Old September 1st, 2017, 05:42 PM
HarrySlother's Avatar
I have a 1972 cutlass that I swapped a motor in recently. I also swapped the dash and steering column. I don't know what worked before because it was not running when I bought it. The headlights have no power but the blinkers work. The car was points and the motor I put in it is hei. I hot wired the hei to a on off switch and the ignition to a push button. That all works.
what dosent work is the lights, windshield wiper and, (when I turn them on there's a click near the wipermotor) the heat dosent work. For the dash when I try to crank it the hot and gen light comes on.
i don't know much at all on how to wire the dash and what does what. I have several loose plugs under the dash but everything I've listed that dosent work is plugged in.
the passenger floor light comes on when I open the door. And I haven't put the dome light in so I don't know if that works.
also I would like to replace all the fuses so if anyone can tell me all the different types of fuses I need and what there for.
HarrySlother is offline
Jetstar 88
June 28th, 2013 08:34 AM
carlstretch
April 22nd, 2013 08:32 AM
Freddy B
July 21st, 2012 06:41 PM
GoBigRed
June 9th, 2008 02:07 PM
Jaked
September 3rd, 2004 04:45 AM
Quick Reply: 1972 cutlass no lights and most of interior does not work
