Wiper Woes - 70 Vista Cruiser
Old Jan 21, 2017 | 03:51 PM
gratsoy's Avatar
Spent this afternoon installing a new switch in my 70 after I discovered that the wipers weren't parking.
I had assumed that this would clear the problem right up, but it's still not parking properly.
I won't rule out that it might be a bad switch, it is Chinese after all. However I pulled apart the old one and they're a pretty basic (and not very quality) design.
It will sometimes park, I noticed that if I fool around with the switch by putting it in the off position and moving it around left and right a bit I might get it to park. I did one time notice a spark inside the switch when doing this.
Currently I don't have the actual button so I'm just using the shaft - not sure if this would matter.
The washer pump doesn't work when I push in either but I doubt that's an issue with the new switch.
Does anyone have any ideas? I'm wondering if maybe I just have a poor ground that's preventing them from parking or if maybe I do have a dead on arrival switch?
Old Jan 21, 2017 | 03:57 PM
gratsoy's Avatar
I should add that both High and low speeds on the new switch work fine!
Old Jan 22, 2017 | 06:53 AM
Most likely the problem is the park relay in the wiper motor, or the wiring that controls it.
Old Jan 25, 2017 | 08:44 PM
gratsoy's Avatar
I would agree, likely the part circuit.
I pulled the motor to do some bench testing and noticed that some of the internal mechanism (plastic) used for the pump was broken. SO I will replace the whole unit and see if that resolves the issue.
Old Feb 1, 2017 | 07:40 PM
gratsoy's Avatar
Spent some time on the phone with someone who repairs these and they confirmed that it is an issue with the parking mechanism inside the motor.
I am sending it out for restoration rather than replacing with a repo.
DennisG.
Vista Cruiser & Wagons
46
Jan 19, 2022 01:22 PM
BeenThere
May 22, 2016 02:32 PM
oldspackrat
Mar 12, 2015 06:34 PM
Olds Dad
Sep 5, 2012 05:30 AM
Redog
Nov 15, 2006 05:20 AM
