Code 34
Old April 18th, 2016, 12:03 PM
Copper Nine Eight's Avatar
Code 34
I check my car for codes and I got code 34. I look in my Haynes book and it says the DPS/VAC sensor needs to be replaced. My question is can you buy a DPS sensor or will I have to go to the junk yard and try there? I looked online and no luck.
Copper Nine Eight is offline
Old April 18th, 2016, 12:06 PM
What kind of car is it, and what engine does it have? Your car should be new enough that you can order a new DPS/VAC sensor at the auto parts store. However, why do you have that code? It might not be a bad sensor. What is the car doing?
Olds64 is online now
Old April 18th, 2016, 12:17 PM
I forgot to mention what car I have smh. It's a 1985 delta 88 307 v8.
It shuts off while I'm driving. I use to be able to keep it running but I did an oil change and replaced the fuel filter and after that the check engine light came on. And now I'm here..
Old April 18th, 2016, 01:45 PM
Throw away the Haynes. Get a factory Chassis Service Manual. The CSM has detailed troubleshooting charts for each error code. The problem often isn't as simple as replacing a part, especially on the CCC system.
Code 34 indicates a low voltage out of the MAP sensor. Standard Motor Products AS10, available everywhere. Of course, it could also be caused by a bad connector or a bad vacuum hose to the sensor. The MAP sensor is mounted on the passenger side inner fender under the hood.
joe_padavano is offline
Old April 18th, 2016, 01:59 PM
Thanks man!
war eagle
September 12th, 2015 04:28 PM
Boldsmobile
November 2nd, 2011 06:02 PM
rrielley
February 9th, 2008 10:43 AM
camaro4x4
January 6th, 2007 08:56 PM
D. McHenry
June 19th, 2006 05:07 AM
Quick Reply: Code 34
