Wire identification 1968 442
Old May 31, 2025 | 05:10 PM
Tony4-4-2's Avatar
Hi there. I just removed the rear bumper from my car and I found this wire. It wasnt connected to anything, it was just hanging there. I didnt see it on the wiring diagram but I might just be blind. Thanks for the help!
Old May 31, 2025 | 05:20 PM
That plug is a basic/standard trailer/hitch lighting plug.
Old May 31, 2025 | 05:25 PM
Tony4-4-2's Avatar
Huh.. thats what I originally thought but I didnt think it made sense. There doesnt seem like there is anywhere to put a hitch. Im asuming its not factory...right?
Wire colors often vary by manufacturer. Likely someone was towing a trailer at some time I suspect.
Old May 31, 2025 | 05:28 PM
They can often be installed quickly at a rental agency. I don't know if a trailer hitch &/or wiring assembly was an available option for a 1968 4-4-2.
Old Jun 2, 2025 | 06:08 AM
RPO U89, Wiring Harness, Trailer Electrical. A $10.53 option for 1968. Olds did not offer a trailer hitch from the factory. You needed to have that installed by the aftermarket if you wanted to pull a trailer. There were also "clamp-on" hitches available for lightweight trailers that did a good job of bending the back bumper.
Old Jun 2, 2025 | 07:24 AM
Joe - Great feedback. Yeah, those "clamp-ons" were the unfortunate go-to hitches back in the 60s early 70s for us cheap kids w/ no $$. They were great for bending bumpers.
Old Jun 2, 2025 | 11:13 AM
droldsmorland's Avatar
CH3NO2 LEARN IT BURN IT
You can tell if it's OEM or not.
Look for the hack....Scotch-locks or non-sealed stake-ons or other hackery.
If it's OEM, wrap it back into the harness and tape it with loom tape, not standard electrical tape. If it's "other", remove it and seal the breach in the wire insulation by cutting & properly splicing (solder & glued shrink tube).
I cannot imagine clamping that bumper hitch to a 68 - 69 or any bumper I cared about !!!!
Old Jun 3, 2025 | 03:58 PM
Tony4-4-2's Avatar
Thanks all for the help. I doubt its stock. The way it was wired in was horrible. One of the wires was about a foot longer than it should be and was wrapped in a coil secured with electrical tape.
Old Jun 3, 2025 | 04:36 PM
Definitely a hackopotamus.
TAM
Sep 27, 2024 07:24 PM
centonze
Dec 13, 2023 04:58 PM
maybe368368
Jun 5, 2023 02:09 PM
Navyman53
Aug 19, 2022 11:35 PM
SoRare
Jun 8, 2009 07:42 PM
