Wire connector for temperature sender - 60 Olds
I need to replace the plastic wiring connector on my temperature sender/sensor (see pictures) on my 60 Olds -- wires are frayed and the plastic connector has seen better days. Does anyone know where I can find this? Fusick's doesn't have. Have checked with various parts suppliers and on a few parts cars and am coming up empty.
Many thanks,
Mark
Many thanks,
Mark
Replace the wires as far as possible and find some 2 connectors that fir the sensor to replace the one you pictured.
That is what I would do, unless this is a concourse restoration.
1959 - 1962 OLDS Temperature Sender
And even the ++ CORRECT ++ Temperature Sender is difficult to find --
N.O.S. ONLY -- it is obsolete from all regular channels...
I have the ++ CORRECT ++ Temperature Sender -- as far as wires -- you will have to custom cut your own -- or splice --
Best always to call me -- Craig -- 516 - 485 - 1935...New York.
