Wire connector for temperature sender - 60 Olds
Old Feb 22, 2012 | 05:38 AM
misercola's Avatar
I need to replace the plastic wiring connector on my temperature sender/sensor (see pictures) on my 60 Olds -- wires are frayed and the plastic connector has seen better days. Does anyone know where I can find this? Fusick's doesn't have. Have checked with various parts suppliers and on a few parts cars and am coming up empty.
Many thanks,
Mark
Old Mar 3, 2012 | 12:41 PM
radioburningchrome's Avatar
Replace the wires as far as possible and find some 2 connectors that fir the sensor to replace the one you pictured.
That is what I would do, unless this is a concourse restoration.
Old Mar 4, 2012 | 09:29 AM
D. Yaros's Avatar
Is it not possible to slide the wires forward, and out of the plastic cover housing, clean up the contacts, install new wire leads and put it all back together again?
Old Mar 5, 2012 | 01:13 PM
mpolds's Avatar
1959 - 1962 OLDS Temperature Sender
And even the ++ CORRECT ++ Temperature Sender is difficult to find --
N.O.S. ONLY -- it is obsolete from all regular channels...
I have the ++ CORRECT ++ Temperature Sender -- as far as wires -- you will have to custom cut your own -- or splice --
Best always to call me -- Craig -- 516 - 485 - 1935...New York.
tru-blue 442
Feb 25, 2015 06:08 AM
wisniows
Feb 2, 2014 10:40 AM
DJS70cutlass
Aug 24, 2011 07:51 PM
wikkonado
Jun 19, 2010 10:36 PM
tarheeldoc
Jun 3, 2009 06:42 AM
