This wire
Old May 27th, 2019, 12:43 PM
F85 330 ctls's Avatar
This wire
I changed my ignition and ignition switch and noticed this wire dangling, as you can see it’s an orange wire connected to a brown wire, my car is a 67 f85 330 v8 Any help would be appreciated,thanks again.
F85 330 ctls is offline
Old May 27th, 2019, 12:59 PM
It looks like it's an accessory item. Looking at your fusebox, I would disconnect the battery and give those contacts a serious cleaning.
Allan R is offline
Old May 27th, 2019, 03:41 PM
Olds Fever
CRUZN 66's Avatar
Just to clarify photo view, is the orange wire cut or does it go to the back of the fuse box??? X2 that it may be an accessory wire...
CRUZN 66 is offline
Old May 27th, 2019, 06:31 PM
The orange wire comes out of the wire harness and that wire is connected to the brown wire.
Old May 27th, 2019, 11:57 PM
Randy C.
rcorrigan5's Avatar
If that brown wire goes through the firewall and into the engine compartment, it could very well be the hot connector for your underhood light.
Randy C.
rcorrigan5 is offline
Old May 28th, 2019, 10:37 AM
1968 442 Convertible
bry593's Avatar
Orange is 12V power all the time with the key off. Yellow is key on 12V. The orange wire goes to clock, cigarette lighter, glove box light, map/dome lights and courtesy lights. When using an aftermarket radio, connect orange to the memory wire. White is ground wire for dome and courtesy light switches.
Not sure why a brown wire is attached to it. Might be someone had gotten creative at some point. There is a brown wire that plugs into the HVAC, but it is clearly not to be plugged into an orange wire.
bry593 is offline
Old May 29th, 2019, 10:31 AM
Thank you
friesjh
September 18th, 2019 07:09 PM
70 ctls
February 13th, 2016 02:02 PM
Icee5150
September 1st, 2013 10:16 AM
stingger68
March 2nd, 2010 04:12 PM
Deputy442
September 2nd, 2008 10:58 AM
Quick Reply: This wire
