Wiring an original head unit into a modern amp
I have a ‘72 Delta 88 convertible.
i am wanting to keep the OEM AM/FM head unit, but run the high level outputs from the original headunit into a modern Bluetooth amp. The original head unit has common ground outputs and requires 10 ohm speakers.
I plan on installing modern 4 ohm speakers and powering them with the modern amp. Obviously this system uses floating grounds for the speakers. The amp also requires floating ground high level inputs from a head unit if one is used. I found a floating ground adapter, however it is designed to use a floating ground head unit with common ground speaker wiring.
Two questions:
Would it penpossile to just split the common ground output to both input channels on the amp?
And if not:
Is it possible to use the available floating to common ground adapter in reverse?
Two questions:
And if not:
Sound stream makes a 4 channel amplifier that allows line level inputs from a factory head unit as an input to the amp. It also accepts a Bluetooth signal from a phone to stream music as well.
The original stereo has a common ground for the speaker outputs and the aftermarket amp accepts floating ground inputs.
Im wondering if one can simply split the common ground into four wires and hook to the amp.
