Wiring an original head unit into a modern amp
Old May 27th, 2019, 05:17 PM
bjfox1970's Avatar
I have a ‘72 Delta 88 convertible.
i am wanting to keep the OEM AM/FM head unit, but run the high level outputs from the original headunit into a modern Bluetooth amp. The original head unit has common ground outputs and requires 10 ohm speakers.
I plan on installing modern 4 ohm speakers and powering them with the modern amp. Obviously this system uses floating grounds for the speakers. The amp also requires floating ground high level inputs from a head unit if one is used. I found a floating ground adapter, however it is designed to use a floating ground head unit with common ground speaker wiring.
Two questions:
Would it penpossile to just split the common ground output to both input channels on the amp?
And if not:
Is it possible to use the available floating to common ground adapter in reverse?
bjfox1970 is offline
Old May 27th, 2019, 06:12 PM
I guess I don't understand what you want as the end result. Do you plan to use the Bluetooth amp with a phone to play tunes? Or do you want to use the OEM radio to play tunes?
Fun71 is offline
Old May 27th, 2019, 07:46 PM
bjfox1970's Avatar
Sound stream makes a 4 channel amplifier that allows line level inputs from a factory head unit as an input to the amp. It also accepts a Bluetooth signal from a phone to stream music as well.
The original stereo has a common ground for the speaker outputs and the aftermarket amp accepts floating ground inputs.
Im wondering if one can simply split the common ground into four wires and hook to the amp.
Old May 28th, 2019, 10:42 AM
1968 442 Convertible
bry593's Avatar
I've never done this conversion, but that seems like the only real way to do it. Have you tried it out?
bry593 is offline
Old May 28th, 2019, 11:45 AM
OLDSter Ralph's Avatar
Let me see if I understand this. You are trying to make a GM AM/FM radio and 8 ohm speakers sound like an AM/FM STEREO radio and 4 ohm stereo speakers with some new fangled gadgets ?
OLDSter Ralph is offline
Old May 29th, 2019, 02:16 PM
bjfox1970's Avatar
No, I’m wondering if a can hook a radio with common ground speaker wiring into a modern amps line level inputs which are a floating ground system.
The amp will be wired to modern 4 ohm speakers
Old May 29th, 2019, 02:30 PM
https://www.crutchfield.com/S-9Ixtxa...d-Adapter.html
oldcutlass is online now
Mike77
March 5th, 2017 08:58 AM
cublex
April 15th, 2016 07:36 PM
Maverick
April 26th, 2015 01:23 PM
60193W30
November 5th, 2012 06:49 PM
ziff396
April 23rd, 2012 03:42 AM
Quick Reply: Wiring an original head unit into a modern amp
