What relay for electric choke conversion?
Old Apr 25, 2020 | 05:55 PM
4speed455's Avatar
I’m trying to take care of as many low cost things as I can on my to do list since I have a lot of free time right now. Up next is wiring up the electric choke conversion on my Quadrajet. I read Joe’s article below. I wanted to use the relay method since I have an oil pressure sending unit for gauges and not a switch for the dummy light. I don’t want to T both units into the oil pressure line and have a bunch of fittings and two switches, it would look to cluttered. I understand that if the belt brakes the choke will close and I’m okay with that. In the article I could not find a part number for the relay. Has anybody else done this, or does anybody know what relay would work? Thank you.
https://classicoldsmobile.com/forums...-wiring-31892/
Old Apr 25, 2020 | 07:01 PM
Any 12v relay will work, Bosch 332019150 Relay is a good quality unit .
Old Apr 25, 2020 | 07:02 PM
VC455's Avatar
Barely Registered
Originally Posted by 4speed455
I...what relay would work?
As Eric noted, many manufacturers make them and many parts stores have these. If you will mount this where it could get wet, consider one similar to
Amazon Amazon
Old Apr 25, 2020 | 07:22 PM
Most of those generic relays are at least 30 amps, so they'll be fine. Heck, you can get a 5 pack of them on Amazon right now for $10, with the sockets.
Old Apr 25, 2020 | 08:11 PM
4speed455's Avatar
Thanks for the responses, and thank you Joe for writing it up for everybody. I bought a waterproof one like VC455 linked to above. I plan to mount it on the fender forward of the horn relay close to the alternator.
Old May 20, 2020 | 02:54 PM
4speed455's Avatar
To close this thread out I have completed my electric choke/relay harness. Total cost about $30. I bought the relay, some packard 59 terminals, ring terminals, in-line fuse holder and some harness tape. I reused some old wire harnesses for the wire and connectors. I didn’t want to cut into the existing harness to tie into the alternator field wire so I removed the terminal from the connector and made a completely removable inline adapter from two wires to one. I ran the fused power wire to the horn relay.
Old May 20, 2020 | 03:49 PM
Nice
1968_Post
Jul 21, 2020 05:38 PM
tgilligan
Dec 7, 2017 02:04 PM
Al Sanchez
Mar 5, 2013 04:49 PM
76Supreme350
May 16, 2011 05:41 PM
HouTXCutlass
Jul 26, 2010 09:04 AM
