2 connections to IGN terminal?
Hey,
Can the HEI and electric choke both be connected to the ignition terminal on the fuse panel? If not, what would the best remedy be? How many connections there are too many?
What can the BAT terminal in the fuse panel be used for? Is it a constant voltage?
Thanks,
Rob
Thanks,
Rob
imo, the best way to do these connections is to use a relay with the coil being driven by the ign terminal. the supply pole of the relay could be connected to the wiper or heater fuse OR the bat terminal(which is always hot, regardless of the ignition switch). i prefer the double redundancy method. i used another relay driven by the oil pressure idiot light that switches the power to the electric choke off when the oil light is on. that prevents the choke from heating if the car stalls unattended during warm-up. don't overlook proper gauging of these wires and proper fusing too. use a relay with a 30 amp capacity and continuous duty ability.
bill
bill
bill
bill
Thanks,
Rob
yes, you're grounding the idiot light thru the choke
I power the HEI by the IGN tap on the fuse block.
I power the electric choke by one of the wires that originally went to the TCS switch on the right side of the intake
bill
