Upgraded Oldsmobile alternator
Instead of hijacking a recent thread...
Did Oldsmobile ever put dual or upgraded alternators on coach built or service vehicles? I've seen 68 & 69 Oldsmobile 98 hearses; as well as, the 67 Oldsmobile Apprehender. Here's a cool article, apparently Oldsmobile didn't upgrade the alternator in the Apprehender:
https://www.hemmings.com/stories/art...oldsmobile-b07
I thought it was cool!
I ask because I know Ford offered dual alternators on 80s/90s trucks outfitted as an ambulance. If Oldsmobile ever did something similar finding the alternator brackets would be like finding hen's teeth.
Apparently Leece-Neville alternators are still around:
https://www.prestolite.com/products/alternators/
Don't forget to consider the size of factory harness wire back to starter or battery or lug on fender when you raise charging amperage. Most Cutlass vintage GM are #10 CU which might be OK at full capacity intermittent duty if you don't drive with a dead battery at night with the lights, cooling fan and boom boom sounds all adding to the heavy draw. Check it out to avoid fire or smoking insulation, I've seen this where a drop-in 100a internally regulated alternator replaces a factory 45a externally regulated job when the owner drives with a dead battery.
Interesting. I guess coach built Oldsmobile hearses or ambulances very well could have been equipped with an aftermarket heavy duty alternator.
Off topic or off my rocker? (Both?) This thread reminds me of growing up in the 1960s and the introduction of a soon-to-become life-saving well-known appliance by Mr. George Hurst. Y'all know what I mean...correct? Probably needed a HD Alt when that bad boy was running.
Olds commercial modifier Cotner-Bevington used higher output alternators in their 66 98-based ambulances. I saw one in a boneyard in CA a year or 2 back. CB also made hearses if I recall.
The alternator was so oversized that they had to notch the hood support to allow it to fit. Still had a voltage regulator I believe. It looked GM, but a lot bigger than I’d ever seen in a ‘66 98.
I looked at the electrical pretty carefully and they had a bunch of non-Olds generic screw terminal connectors presumably for stuff like the siren and extra lights.
The body panels were modified as you can imagine and the trim inside was non-Olds. The other thing that was kind of unusual was that the glass was more flat than factory.
Chris
Chris
Edit - Found the print version.
Check out one of the biggest Oldsmobiles ever built. I wish they had more info on it:
https://emsmuseum.org/collections/ar...ton-ambulance/
Cool ad!
oldsmohaulic
Dec 18, 2009 11:02 AM
