Oldsmobile Registry??
The wording of your question is peculiar i.e. "was in existence" implies/imparts the notion that for any (previous) point in time how many Oldsmobiles were in existence on a particular date. That would be impossible to ascertain. Even if you began with the total number of Oldsmobile models produced during a given model year, you could not state how many exist at a given point in time (how many were complete losses, totaled, etc.).
So, a couple things - you can find the total number of Oldsmobile vehicles produced during a given model year e.g. A-Body, f-85, 442, Delta, Toronado, etc. If what you're asking is how many were produced, yes this information is available.
Regarding registry (of sorts). There are select members here who do maintain a registry of extremely rare Oldsmobile models (e.g. W-30, W-32, manual vs. automatic, floor console shift vs. column shift, etc.) - but that data is exceedingly rare to find.
Perhaps if you broadened your question a little others can assist in determining exactly what you're trying to achieve.
Any registry is only as good as the data entered into it. You have no way of knowing how many cars still exist that are owned by people who either don't know about the registry or don't care to have their information recorded. I think people loose waaaaay too much sleep over the "one of 27" or "one of only three known to exist" BS. You can get production numbers by year and model here.
By comparison, in the 1971 model year there were 114,630 Camaros, 515,625 Chevelles and Monte Carlos, and 149,678 Mustangs built. To be honest, the 71-73 Mustangs and second gen Camaros are not that common at shows and cruise nights.
Better look again. That's 163,949 Cutlass, Cutlass S, Supreme, and 442 2dr hardtops and another 4,503 Cutlass S sport coupes for the 1971 model year. Total Olds A-body production was 259,692.
Here is the URL:
http://wildaboutcarsonline.com/membe..._1956-2004.pdf
Dang, I see the whole URL, in it's entirety on the post "quick reply" edit window. Then when posted it truncates it. Maybe you can hover over it, then copy the whole URL.
Here is another version, that I did not add the "link" to.
Well darn, that didn't make a difference. Try the Hover/Copy trick, maybe you can get it that way.
Those are the model line numbers, and what they mean depends on the year. For 1965-71 these correspond to the second and third characters of the VIN. They are also on the cowl tag. This is all covered in Section 0 of the CSM for each model year in addition to the PIM. As an example, this chart is from the 1969 PIM. Note the "Series" column. The leading "3" means Oldsmobile. The second and third characters are the series or model line. The "00" is replaced by the body code in the VIN and on the cowl tag. "67" is convertible, "77" is Sport Coupe, "87" is Holiday Coupe, etc.
I noted the description of a driveaway chassis was discontinued in the 1971 model year (at least in the PIM).
Obviously a driveaway chassis is listed in the PIM then stops in 1971. Do you have any knowledge of the history of these, application, etc.?
The driveaway chassis was used for ambulance, hearse, and limo applications. I'm not sure why it is no longer listed in the later PIMs.
twilightblue28A
June 30th, 2021 09:12 AM
easytobedead
January 16th, 2010 08:04 PM
oldsmohaulic
December 18th, 2009 11:02 AM
