turn signal switch
turn signal switch
Im shooting in the dark now. I cannot figure out why my passanger side , front blinker will not blink. Rear light will blink.Driver side works fine.Checked wiring, checked socket, checked ground, no blink. I do hear the switch making a blinking sound. Passenger side light will come on with headlight and as running light. Can one side of the "turn signal switch go bad?
Having trouble with windshield wipers also. Cannot get them to work. Was working fine before starting restoration.Can someone shed some light on how to test wiper motor?
Any help would be greatly appriciated,
1972 Cutlass Supreme
You do realize that the 1157 bulb has two filaments, right? One for the park/tail lights and one for the brake/turn lights? They usually burn out at different times. Did you try swapping the bulbs side-to-side?
Unfortunatley joe that did not work. Moved diver side wire over to check passenger light fixture.
Made it " blink " fine. I was hopeing not to go into steering wheel. Not sure what else to do.
I'm sorry, but I can't follow what you typed. You moved the "wire" over? I suggested that you simply swap bulbs from side to side. Is that what you are saying you did?
Hi Joe,
I made sure that both of the bulbs worked. I disconnected blinker light sockets , took a wire and ran it from working side and ran wire over to check passenger side socket. It worked. So I'm leaning towards replacing turn signal switch. Would you have any suggestions before I pay out money. I also took contact electrical sray and cleaned the wire connections that go through firewall to fuse box.
Thanks for your help
Shay
Shay
Hi Joe,
Shay
Shay
Joe, found the light blue and blue wire at base of steering column. Applied 12V to each, each turn signal light came on when applied. So I guess im heading to the Turn signal switch.
Also ran 12volts to the windshield wiper motor that I could not get to work. Motor moved about 1/2 a rotation and stop. Never moved agian. I take this as motor is shot. Would you agree?
Thanks agian for your help.........Shay
Joe,,I started to dig into steering column, got steering wheel off and thought I would try some electric contact cleaner. After a couple of squirts on the turn signal switch , Blinker started to work!!! Life is good.
Shay
Shay
dennisspeaks
Oct 1, 2011 06:02 PM
