Test voltage at R Terminal on Generator
Old Feb 15, 2016 | 06:31 PM
pcard's Avatar
70 Cutlass SX
On an externally regulated generator, 1970 Cutlass
Hi Guys: no emergency, but could someone give a description of how to test the voltage at the R terminal of the generator while the car is running?
I am reviewing the Charging System Diagnosis procedure in the 1970 CSM (page 12-7) and would like to understand how to do this safely.
Thanks.
Old Feb 16, 2016 | 03:32 PM
pcard's Avatar
70 Cutlass SX
Just to be clear - I know how to use a voltmeter
I know you are not supposed to disconnect the RF plug with the engine running.
So how do I measure the voltage without disconnecting the RF plug?
Old Feb 16, 2016 | 04:04 PM
classicmuscle442's Avatar
Use a paperclip into wire connector to measure volts while running. Just set it up before starting.
Old Feb 16, 2016 | 04:19 PM
Can you use a pointy needle probe (pig sticker) to contact the R terminal from the backside of the connector?
Old Feb 16, 2016 | 04:49 PM
pcard's Avatar
70 Cutlass SX
Great - thanks very much!
shamusj
Mar 4, 2016 06:48 AM
dom992
Aug 7, 2014 11:26 AM
delta_88_germany
Feb 22, 2014 01:48 PM
IB Adrian
Sep 12, 2009 12:43 PM
