Turn signal stays on
Turn signal does not blink on and off for both directional’s. I checked all the fuses and bulbs. The flashers work fine.
I recently converted to HEI so I was under the dash using the IGN 12v supply for the distributor but the signals worked after that. I did accidentally hit the IGN 12v wire on the firewall when the key was on and got a spark but the signals worked after that.
They seem to work intermittently it depends on the day.
Thoughts?
Thoughts?
There are 2 signal flasher units under the dash. One is for your 4 ways, the other for turn signals. It's probably that!
They are round, approx 1 1/4 inch in diameter and 1 1/2 inches tall. They hang from the wire harness and have a 3 or 4 wire plug attatched to it. On some cars they plug directly into the fuse box.
costpenn
June 24th, 2015 10:38 PM
night_tigeronthehunt
September 27th, 2009 04:46 PM
