Turn signal indicator on dash stays lit
Old Oct 8, 2013 | 02:30 PM
Winger67's Avatar
1972 Cutlass Convertible
With the headlights on, the right turn signal indicator on the dash stays lit. All exterior bulbs are lit. When I signal right turn, the dash indicator flashes, the front right flashes, front side marker does NOT flash, rear flashes.
Suggestions?
Old Oct 8, 2013 | 03:18 PM
Suggestions?
Sounds like the RF signal light has a burnt out filament. When the lights are on, is the RF lamp lit when the signal is off?
Old Oct 8, 2013 | 03:22 PM
Winger67's Avatar
Yes. The RF is lit when the signal is off.
Old Oct 9, 2013 | 11:58 AM
You might want to disconnect the front signal lamp harness from the main electrical and check the contacts for corrosion. Spray it with some Electrical contact cleaner, not carb cleaner or brake clean. I had that problem happen with my car (ironically the same side) many years ago, and it was a faulty connection at that clip in area.
costpenn
Jun 24, 2015 10:38 PM
oxford
Oct 17, 2013 09:24 AM
PGH Cutlass
Sep 29, 2011 05:29 AM
1971viking
Jul 5, 2011 08:01 AM
Big Joe P
May 23, 2007 04:29 AM
