Cold light in dash stays lit
Old Oct 14, 2013 | 09:49 AM
oxford's Avatar
1962 starfire; cold lite stays lit in dash when engine running or key on. Temp. Sending unit has 2 connectors. 1 wire connected to sending unit and grounded to vacuum advance unit. Hooked another wire to other connector on sending unit and tried grounding it, switching with other wire and lite stays on. Any help greatly appreciated. Thanks
Old Oct 14, 2013 | 11:05 AM
d2_willys's Avatar
One connection is for the cold light, the other for the hot light. The sender is grounded via the threads in the manifold.
Try pulling the two pin connector off the sender and see if the light goes out. If so, then the sender is bad. If the light still is on, then you probably have a shorted cold wire to ground somewhere.
Grounding either of the wires will light the appropriate light when the ignition is on.
Old Oct 17, 2013 | 03:54 AM
oxford's Avatar
Cold light stays lit
Thanks;
Tried and light still on. Just a thought before I purchase another sender, there is plumbers Teflon tape around the base where it screws in, do you think that might not let it ground? Appreciate your answer.
Old Oct 17, 2013 | 06:44 AM
Thanks;
Just so we're clear, you disconnected the wires from the sender and the light is still lit? If so, the problem is NOT the sender and replacing it will not fix anything.
Old Oct 17, 2013 | 09:24 AM
oxford's Avatar
Cold lightays lit
Disconnected ALL wires to sender and let engine warm up and doggone light is still on. Any other suggestions ? Thanks
Winger67
Oct 9, 2013 11:58 AM
dschallock
May 24, 2011 05:19 AM
71supreme
Nov 2, 2010 09:10 PM
jugdish
Jun 24, 2010 06:41 PM
night_tigeronthehunt
Sep 27, 2009 04:46 PM
