turn the key starter turns engine doesn't
I turn the key starter turns engine doesn't.
Happened suddenly
I turn the key a few times and then it "Catches" and I'm off.
Is it the flywheel missing a tooth or starter solenoid?
Anything else?
joepenoso
PS 71 Olds 455
Happened suddenly
Anything else?
joepenoso
PS 71 Olds 455
Bad flywheel, disconnected solenoid lever, bad starter drive (including bad drive gear) are all possible. Since the starter is turning, a bad solenoid is lower on the list.
Only way to tell is to drop it.
Can you remove the inspection cover and see if the bendix or flexplate are stripped?
Apparently a rebuild kit for a stater is not that pricy, Allan R just did his in his build thread.
Flexplate i have no idea, but i assume you can get a good/used one from someone on here.
I ordered a Summit mini starter and will check the teeth when I switch it out. The starter turns in the air 3 or 4 times before the solenoid forces the teeth to mesh. I know it will only get worse.............so I ordered a new starter
joepenoso
joepenoso
It was more or less working like a 350 cubic inch air pump...
86ChebbyWagon307
July 5th, 2011 07:09 PM
JMW803
May 13th, 2010 04:43 PM
