84 cutlass diesel tach issues
At some point the alternator shorted out causing a trace on the printed circuit for the tach to burn in two. I ran a jumper wire thinking it would bypass that. It still doesn't work. The tach responds at times but only burys itself to 0 or redline. also i took the alternator off and had it checked and it works just fine. Anyone got any ideas what could be the problem? Also I installed hid headlights for the low beams and when I go to turn the brights on the hids shut off and the original brights come on instead of both being on when the brights are on.what could cause this?
RAMBOW
May 3, 2022 04:25 PM
