Trunk Light wire - connection wiring
Old May 22, 2023 | 05:16 AM
JVCCutlass's Avatar
1971 Cutlass Supreme convertible.
Looking for information about where the trunk light wire connects into the wiring harness. I've cleaned up the light and contacts but I have no 12v on the wire.
Any help on where the 12v wire connects to the wiring harness, I'm guessing under the hood someplace? All of the fuses in the block under the dashboard are good and all of my other lighting is working fine.
Thanks...Joe
Old May 22, 2023 | 05:23 AM
It should be an orange wire emanating from the wiring harness into the trunk. The wiring harness is held to two clips located on the LH (driver) side in the trunk. The orange wire leaves the wiring harness first (early) to connect to the hinge mounted lamp holder.
Old May 22, 2023 | 05:28 AM
This link may help >>>
Factory trunk light wire extension
green1972
Jun 15, 2022 02:44 PM
724drcutlass
Feb 6, 2021 05:23 PM
brown7373
Jan 24, 2014 03:46 PM
rocketman77
Nov 11, 2013 06:40 AM
ziff396
Dec 15, 2012 10:43 AM
