Tail light sockets removal ?
Old January 22nd, 2013, 12:11 PM
Houston_t's Avatar
How do I go about removing the tail light sockets on a 71 cutlass and where can I find replacements ?
Houston_t is offline
Old January 22nd, 2013, 12:38 PM
They should be crimped to the pod. Mine were not corroded so I didn't have to remove them - just cleaned them up. However to remove them you need to lift the crimp on the inside of the pod enough to let the socket slide out the back. Use a flatblade screwdriver and lift up a little bit of the crimp at a time as you work your way around it. Replacement 'universal' sockets available here or here not very expensive.
Allan R is offline
Old January 22nd, 2013, 01:17 PM
Houston_t's Avatar
Cool thanks for the help, that's exactly what all I needed to know. One of mines is crap and the rest look salvageable but for those prices I will just replace all of them and be done with it
Al Graaf
January 20th, 2012 01:15 PM
bonnevillegreg
November 2nd, 2011 07:42 PM
KZ442
December 7th, 2009 06:11 PM
TripsJohnson
April 29th, 2008 10:52 PM
TripsJohnson
April 29th, 2008 10:51 PM
Quick Reply: Tail light sockets removal ?
