Tail light sockets removal ?
They should be crimped to the pod. Mine were not corroded so I didn't have to remove them - just cleaned them up. However to remove them you need to lift the crimp on the inside of the pod enough to let the socket slide out the back. Use a flatblade screwdriver and lift up a little bit of the crimp at a time as you work your way around it. Replacement 'universal' sockets available here or here not very expensive.
