Tach reading high
Old Apr 15, 2012 | 11:23 PM
Magna86's Avatar
Tach reading high
Ok finally found a tach I like and wired it in today. First off it looks great minus the red illumination. Hope I can fix that. Problem I have is it reading 200-400rpm higher than what my digital timing light says. Everything is all good and snug. Its wired direct to tach on hei distributor was I supposed to have a resistor inline? Any help be great.
Old Apr 16, 2012 | 01:23 AM
garys 68's Avatar
No ballast resistor on HEI. Bad spark plugs, wires, disributor cap can cause high readings.
Old Apr 16, 2012 | 04:50 AM
Oldsguy's Avatar
Past Administrator
Finally, if it is an older unit that you bought from someone else used then it might need an adjustment. If there is no stop, does the needle read zero when the engine isn't running or does it drop lower than zero. If the reference is lower than zero then your error will be off by that much. Some tachs have an adjustment for that. Just a thought.........
Old Apr 16, 2012 | 05:59 AM
Magna86's Avatar
Sorry the cap/plugs/rotor/wires/coil/module and wires are new. Tach was new in box. Only adjustment was choosing which cyl/pulse setting. Tach reads 0 when not running.
Old Apr 16, 2012 | 01:47 PM
allyolds68's Avatar
If you search here there a a few posts about repro tachs not reading correctly and a few posts on how to fix it (not that you should have to with a new one )
https://classicoldsmobile.com/forums...ation-how.html
RAMBOW
May 3, 2022 04:25 PM
HitTheHole
Nov 18, 2013 02:46 PM
starfire
Sep 10, 2013 08:43 PM
smcurro
Paint
Jan 29, 2012 02:31 PM
MN71W30
Jun 8, 2011 12:13 PM
