Tachometer Reading High
Old Sep 10, 2013 | 05:49 PM
starfire's Avatar
Just picked up a 1978 Starfire Firenza today. It is a 4-speed with the Chevy 305 (factory, I know, I know, the plan is to unfactory it with an Olds powerplant). It runs real good, but in 4th gear at 40 mph the tach reads 4000. Seems a little high to me. At idle it reads 1100 and it certainly does not sound like it is at 1100. I plan on picking up a cheap tach to hook up and check but I have some questions.
1. Can I have two tachs hooked up at the same time?
2. Any advance thoughts on why the tach is reading high?
Here's the first pictures:
Old Sep 10, 2013 | 05:51 PM
starfire's Avatar
Wait, forget question 1. I know I can have two tachs hooked up. Would like any insight on question 2 though.
Old Sep 10, 2013 | 06:48 PM
dc2x4drvr's Avatar
Yes you can hookup 2 tachs, your factory tach might need recalibration.
Old Sep 10, 2013 | 06:50 PM
brddg's Avatar
Well it's way cooler looking than the 442's of the same era. I guess if I hadn't liked monzas in high school I might not have the same opinion. Maybe it's a tach for a 6 cyl? Yes, you can run two tachs at the same time. If there is an ignition amplifier (msd, hyfire, etc...) you need to address those issues.
Old Sep 10, 2013 | 07:08 PM
starfire's Avatar
Came from the factory with this tach and electronic ignition (and rear sway bar, schwing!). I'll have to look into recalibrating it.
Old Sep 10, 2013 | 07:14 PM
starfire's Avatar
There's a thread over at Oldspower that suggests that the '80's Olds tachs had a tendency to have their plugs get loose or fall out. Either condition causes the tach to act like a 6 cyl or 4 cyl tach. That sounds like what mine is doing. I'll take a good look at it this weekend.
Old Sep 10, 2013 | 07:46 PM
There's a switch or a jumper on 80s Olds tachs that will go from 8 to 6 and read high.
Old Sep 10, 2013 | 08:43 PM
brddg's Avatar
Schwing is right! Cool car man. Got factory stuff and it shouldn't be too hard to fix:
Macadoo
Jun 24, 2014 05:36 PM
HitTheHole
Nov 18, 2013 02:46 PM
Magna86
Apr 16, 2012 01:47 PM
smcurro
Paint
Jan 29, 2012 02:31 PM
bulldog
May 19, 2008 01:29 PM
